very nice, much better- I wonder if I should start playing w/ RAW...
If you are going to post process your images, I think shooting RAW is one of the biggest improvements you can make in the quality of your images.
If you are not going to post process then you need to develop strategies to make the JPEG as good as you can get. My experience in doing post processing is that you can almost always improve the image by making a change to white balance. Many times I just change the WB from As Shot (Auto White Balance) to Daylight, or Shade, or Cloudy. 9/10 times the image improves and I may not even make a tweak to that setting. The message in this is that I believe you can do the same thing in your camera by manually setting WB, although I admit I never took the time to do it. Possibly even better would be to use a WhiBal card to set a custom white balance when you take the shot. Then the JPEG will have much better odds of being correct out of the camera.
I've settled on shooting RAW and then doing the correction after the fact. But, there is the time required to do post processing, and not everyone wants to do that.
I can tell you that I can manage JPEG very well, even when the white-balance was WAAAAAAAAY off. But it is work.
RAW output is different than JPEG output; and I'm not just talking about the bit-depth either.
If a person were to take a RAW + JPEG photograph and process both images; s/he would be hard-pressed to get them to look the same at the end. It would take a very long time, and people would still be able to tell the difference between the two.
From my own experience (over a decade and over a dozen different cameras, 7 of which were DSLRs), I would say that the Sony Rx10 RAW and JPEG are so very different that the output from each process is as if they are coming from different cameras.
In most cases, the ISO noise that Sony incorporates looks MUCH RICHER in Jpeg than it does in RAW where it tends to have the traditional chunky look.
However, in the higher ISO ranges RAW takes the lead away from the JPEG.
The *ONLY* other time I've seen RAW do an easier, better job than JPEG is with snow pictures.
I'm sure that for a RAW processor, it would feel like any picture is easy and fast. But not necessarily better. The Bionz processor that Sony is using to push out the very appealing noise is not as visible in RAW and that leaves RAW behind in most instances.
The JPEG usually comes out fairly close to done when the settings are right. Just a few minor tweaks can really make the picture shine.
Also, I picked up a Sony 43 flash, and Auto WB seems to like it just fine (i.e. it picks flash WB). But not only that, just the overall bounced light makes every image far more ready to be processed.
Anyway Ron, quite a nice read today from your posts.
There are 10 types of people in this world, those who understand binary and those who don't.
