robertseymour
Well-known member
I am currently a user of the DP1X and DP3M, a while back I was looking into a SD15 but I bought a DP3M instead.
I am once again looking at the SD15 after reviewing some recent photos comparing the older 4.75mp chip to the newer 14.7mp Merrill sensor.
I actually prefer the output of the older sensor, it seems to clip highlights better (less), lower noise and higher dynamic range. I also like the fact I can use it straight in Lightroom without having to use SPP.
Initially, I would be looking at a wide angle lens for the SD15, wider than the 16.6mm on the DP1X. I plan to keep both the DP1X and DP3M to cover their respective focal range.
On a recent trip, I had some photos that were taken with the Sun in the frame:
Will the SD15 have similar flare issues?
One thing I would love to keep is the lovely stars that I get from lights on long exposures:
And I guess the 10-20mm is the best lens for me, as I have discounted the 8-16mm as it wont take filters. I want to use ND filters with it, really only on the wide angle.
A fisheye is a possibility but I have never shot with one.
Any experiences with the SD15, Wide Angle Lenses and flare?
Cheers, Rob
Cheers, Rob
