Ken Yun
Active member
I have found that my prints are quite a bit darker than the image when I view it on my monitor. The colors are also not the same (mostly the difference is just darker shades of the same color). This is the basic process I have been following:
1. Download photos from my Olympus C-3000 to my computer using the Olympus software.
2. Open the photo in Photoshop 7.0. When it is being opened to PS, it is converted from sRGB to the “working space”. I make whatever adjustments I need in PS.
3. I open the photo in Qimage. I made all the basic settings in Qimage’s Print Processing Panel and I set the ICC profile that is correct for my Epson Photo 820 printer. I also chose the profile for my monitor (that I created using Adobe Gamma).
4. I set the printer at the highest quality print and using the paper that matches the printer’s ICC profile set in step 3. I also chose “No Color Management” in the printer’s set up.
That’s it. I don’t understand why my prints look so different.
I am mainly using Epson Heavyweight Matt paper. I have also tried using the Epson Premium Photo paper cause I thought it would help with the brightness of the print because it is a brighter paper. It did not make a difference
In desperation in finding a solution, I tried some of these other things:
1. Tried using “ICM” in the printer software’s Color Management controls. No difference.
2. Set the printer mode to “Automatic” instead of “Custom”. No difference.
3. Tried printing from Photoshop instead of Qimage…in case I have something set wrong in Qimage. I used the Photoshop Color Management tutorial from the Computer Darkroom website ( http://www.computer-darkroom.com/ps7_print/ps7_print_mac.htm ). No difference.
4. I considered that maybe something happened when the photo is converted from sRGB to the workspace in Photoshop when I do my touch-ups. I took the raw photo straight from the camera and downloaded it into the Olympus software to get it to my computer. I printed directly from the Olympus software without any touch-ups. No difference.
5. The only thing that seemed to make a difference is when I printed in “Automatic” mode and I used plain photocopy paper. The print was a lot lighter/brighter.
Some of the prints I make look good on their own (if you are just flipping through the prints). As soon as you compare it to the monitor, the prints look so much darker. What it almost looks like is if I took a piece of transparent cellophane that is tinted gray (actually, I’m not really sure what color it is really tinted as the colors on the print are a shade different but I can tell what shade. It makes the colors in the print looks slightly a dirty brownish or dirty greenish) and placed it over the monitor. That is what the prints look like. Colors look duller and whites look off-white. One other thought I had was that maybe it was my monitor and it was brighter than it should be. What I did to check if this could be the problem was to view the photos from the screen on my camera and compare it to what I see on my monitor. They were not that much different so that can’t be the problem either. I am using the Epson ink also so I am completely baffled why I am having this problem.
The only other thing I can think of, and it may have no bearing, is found in Start/Settings/Printers and Faxes/Epson Stylus Photo 820 series (I am using Windows XP). When I right-click this icon and choose Properties, it shows a toolbox called Epson Stylus Photo 820 Properties. The Color Management tab “These settings let you associate color profile(s) with your color printer…” It has a choice of “Automatic” or “Manual” (it is currently set to “Automatic”) and then there is a box under it with a heading that says “Color Profiles currently associated with this printer:”. Within the box, the only profile listed is “EE163_1” so I guess this is the one being used. I have never seen any documentation and I have never read and information that I have seen on forums that mention anything about changes or even accessing the printer’s Properties box. Do you know I need to do here? Maybe this is the problem.
Any help would be greatly appreciated. Thank you in advance.
Olympus C3000
Epson Photo 820
Olympus C3000
Epson Photo 820
