A
Arlene
Guest
Just tried an A7 out at a camera store - jpg's only and I got this weird smearing effect on the skin. See the sample below. The Dp review is accurate - jpg processing is disappointing. I didn't change any settings. Maybe it was on high NR and I needed to set it on low NR or no NR. I'm going to go bk to the store and try again. --Arlene
www.pbase.com/arlene/image/154258312.jpg
If the above link doesn't work or doesn't display clear enough, click on the link below to see it at pbase.com (click on original size to see the problem)
Interested to know if you've run across this problem and how you handled it. --Arl
Loading…
www.pbase.com
