baobob
Just receive my set
It arrives very well packed in a serious cardboard box with the set nested in a very dens foam so the first impression is very good
Mechanically they fit well. I always put on the chinese FX bayonet some silicone oil on the part that are far from electric pins using a q tip sample then carefully remove the excedeent in order the bayonet is free from any unwanted resistance
So both tubes fit well on the body and on 2 lenses tested60mm and 18-55mm
At the beginning there was a problem of correct connection betwwen the 2 tubes together but after practicing carefully several times now everything is ok I would say it's probably wise once the tubes are together to use the very light play in order to make sure that the male and female contacts are ... in contact! As far as I can see it's due to the contacts on the tube (not the pins) that are a bit missing relief so assembling the tubes should be done carefully
Once evrything is ok I got a max 3cm (using a ruler) filling the frame with the 60mm macro mode and 3.5mm for the 55mm zoom
For the 60mm you get a 23.6/30= 0.80 reproduction ratio instead of 0.5 and for the 55mm that was a champion of macro an interesting 23.6/35= 0.67 ratio
This is with the 18-55mm that I'm most interested when I want to carry the minimum of equipment
I'll be testing also the 55-200mm at 200mm to see how I can shorten the focus distance
So 3.5 stars on 5 !
Cheers
Bob
So 3.5 stars on 5 !
Cheers
Bob
