i see that only some cams offer external flash sync, and apparently
they only work with proprietary external systems. it sounds like,
for example, the nikon cp 995 will support external flash but only
nikon speedlights - is that correct? and that the canon c4000
needs a special bracket or something that costs an extra $100.
which 3-4mp cams will support the external flash setup i already
have (pair of vivitar strobes in umbrellas)? vielen dank.
Some of the Olympus cameras (E-10, E-20, C-4000, C-4040, C-730UZ)
have a 5 pin TTL terminal that you can connect a FL-CB04 cable
which has a standard pc-sync output. B&H and Adorama sell this
cable for $40. The C-5050Z, E-10, E-20 have an Olymput TTL
hot-shoe that can also drive a standard hot-shoe flash (or a
hot-shoe to pc-sync converter). Note, the C-5050Z which was just
released, doesn't have the 5 pin TTL terminal, just the hot-shoe.
The new Minolta 7HI has a pc-sync connector on the camera (previous
Minoltas had a hot-shoe for their propitary flashes, but I'm not
sure if it would drive a standard hot-shoe flash).
Somebody else mentioned the Fuji S602.
I believe the Canon G2/G3 have a hot-shoe.
