tomtek1221
Well-known member
- Messages
- 221
- Reaction score
- 9
How do I properly set up back button focus on my D7100?
Here is a link to an excellent article on the basics of setting up and using AF(on)How do I properly set up back button focus on my D7100?
I have this settings on butHere is a link to an excellent article on the basics of setting up and using AF(on)How do I properly set up back button focus on my D7100?
http://www.luminescentphoto.com/blog/2010/11/05/nikon-af-on-technique/
I have my D7100 setup as follows:
Custom Settings Menu
If I want focus tracking I hold the AE-L/AF-L button on the target when pressing the shutter
- f - Controls
- f4 - Assign AE-L/AF-L button
- Press [AF-ON]
Press + command dials [Off]- a - Autofocus
- a1 - AF-C priority selection [Release]
- a2 - AF-S priority selection [Focus]
- a3 - Focus tracking with lock-on [AF-1 Short]
- aa6 Number of focus points [AF51]
If I want to focus and recompose, I lock focus by releasing the AE-L/AF-L button, recompose then press the shutter.
I use single point focus for stationary targets and 9 point group for most everything that moves.
YMMV
Conrad
Show Low, Arizona
- f - Controls
- Press [AF-ON]
YMMV
That is correct.Thanks for replay i will try to say in different words
"Prioryty focus" setting means for me that when I press realise button but frame is out of focus it will not make a picture.
I believe there is an exception with the D7100 and D7200. If you also have menu f4 set to "AF-ON" (back-button focus), then menu a1 and a2 are ignored and the camera will work as if menu a1 and a2 are set to "release". I have not confirmed but I remember reading/learning about it.Mine point is that it does pictures anyway And I can't get this to work.
You can confirm this by simply setting both menu a1 and a2 to "focus" and menu f4 to "AF-ON". Now point the camera (without pressing the AE-L/AF-L button) at a subject that is obviously out of focus (green focus indicator in viewfinder is not solid) and see if the camera takes a picture when you press the shutter release.What do i missing?
This is how it works on my D7100. It can take an out-of-focus photo with menu a1 & a2 set to "focus" with menu f4 set to "AF-ON" (BBF). It would be good to have the "focus"/"release" option for BBF but I have not been able to achieve this. It seems impossible.That is correct.Thanks for replay i will try to say in different words
If you have menu a1 set to "Focus" then when you are in AF-C you can not take a picture unless the green focus indicator in the viewfinder is solid green (the subject is in focus)
If you have menu a2 set to "Focus" then when you are in AF-S you can not take a picture unless the green focus indicator in the viewfinder is solid green (the subject is in focus)
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
This explanation from another thread now explains it for me.
"It is working as designed. This is not a problem. It is same way as D800 and D600. Even Canon works that way. Once you use the back button to achieve focus and release the button the camera will continue to fire no matter where you point the camera. As long as you've achieved the initial focus and release the button the camera will continue to fire away.
Now if you press and hold down the AF and move the camera around it won't fire until focus is achieved. It is working as designed."
That's a good explanation - haven't seen the thread before.This is how it works on my D7100. It can take an out-of-focus photo with menu a1 & a2 set to "focus" with menu f4 set to "AF-ON" (BBF). It would be good to have the "focus"/"release" option for BBF but I have not been able to achieve this. It seems impossible.That is correct.Thanks for replay i will try to say in different words
Thanks.You can confirm this by simply setting both menu a1 and a2 to "focus" and menu f4 to "AF-ON". Now point the camera (without pressing the AE-L/AF-L button) at a subject that is obviously out of focus (green focus indicator in viewfinder is not solid) and see if the camera takes a picture when you press the shutter release.What do i missing?
This is the thread: http://www.dpreview.com/forums/thread/3482589?page=2That's a good explanation - haven't seen the thread before.This is how it works on my D7100. It can take an out-of-focus photo with menu a1 & a2 set to "focus" with menu f4 set to "AF-ON" (BBF). It would be good to have the "focus"/"release" option for BBF but I have not been able to achieve this. It seems impossible.That is correct.Thanks for replay i will try to say in different words
Is it explaned a little more in that thread - it raises some questions, if using AF-C/AF-S focus/release priority will make any changes to the described behavior.
BirgerH.
Would this be the same on the D5500? I know the option is available in the menu.
Well - if you look at sweetgum's post a little higher, Nikon has actually explained it - you don't need to agree in the motives of Nikon, but it is an explanation, which mean, it's not a "bug" but an intended behaviorYes it would be nice if Nikon could explain this bug
