mmmmmmmm
informal test set-up
I have not been happy with a D800 that I purchased a year ago last July. So I would like some advice as to what you might do for a course of action.
Cameras used in test D700(for comparison) and a D800(serial #3020681)
Lenses used during informal test. 50mmf1.4D, 85mmf1.4D, 24-70f2.8, 70-200f2.8VRII, and 105f2.8 macro. All Nikon lenses
NOW THE TEST I set up in a staggered pattern, three identical boxes with the same printing on the side. The camera was on a tripod. Focus was on the center red box. I zoomed in on the LCD to check sharpness. Since I do 90% portraits, I used the lenses at my normal portrait distances. I checked all the above lenses with normal focus and live view. Here are the values I found with the D800 using normal focus, not live view. These values let me focus sharp on the center box.
50mmf1.4D +20 85mmf1.4D +10 24-70f2.8(at70mm) +5
70-200f2.8VRII(at 200mm) +0 105mmf2.8 macro +0
With the D800 and D700, all lenses were shot wide open as I am doing a lot of my portraits with a very shallow depth of field.
With the D700, all lenses were sharp except for the 50mmf1.4D which showed a slight front focus shooting at f1.4. This lens will go.
Since two of the lenses on the D800 required no fine tuning, I am not so sure that there is something wrong with the D800. The 50mm lens concerns me - I am probably going to get rid of it. The Question is should I get ride of the D800?
I know my testing procedure is pretty crude but I think it is a good indication as to its performance. WHAT ADVICE CAN YOU GIVE ME ABOUT THE D800?
respectfully,
David Miller
PS this camera has been back to Nikon twice and both times Nikon said that the focus was good!
