Why does my Sony A65 have
jamiejjj
Member
CO
I have owned one sony a55 and two sonys a65 and all 3 of these cameras have had dust or dirt that would show on the photos when it was first used and brand new. These dirt spots have nothing to do with the lens because the spots are there with different lens. The spots are more pronounced when I am zooming in. Recently the spots have gotten worse as can be seen in the photo. I live outside of the U.S. and took the camera to be cleaned by an authorized Sony dealer and the stains were actually worse afterwards. Does anyone have any suggestions what this could be and how to clean it? Do I need to buy a new part?
Thanks for any help.
Certainly dust on the sensor. Surprised the Sony repair could not get it very clean, not that it would stay that way, but it should come back with at most a few small spots.
Step one, change lenses in a clean environment if possible, keeping the lens opening facing down.
Step two, get a blower with a filter built in like the Rocket Blower, blow off the mirror then raise it, push small button at base of mirror, while pointing the camera down, blow off the sensor. Try to stay away from freon type sprays as the liquid can stick to the mirror and sensor if you are not careful. There are CO2 blowers but you are not likely to run across one in normal camera stores.
Step three, use a lens pen to remove isolated small specks of dust, these sometimes come with the blowers and are meant to pick-up small dust particles. Do not use on mirror just sensor. This is as far as I have ever gone.
Step four, is a wet clean, kits available from various sources I have not done this yet, but a search on this forum should give you a lot of discussions on various ones available and how to use them.
That's terrible, definitely dust or dirt. Where did you buy your cameras. You say an A55 and 2 A65s all had this problem? I've owned 5 different Sonys (A100, A55, A65, A77, RX100) and never had one with this problem. Do you live in an extremely dry dusty area?
That is hard to believe. Did you buy all the cameras from the same vendor?
The SLT mirror is a pretty good dust shield--dust on the mirror is far less noticeable than dust on the sensor. I have an A55 and an A57 and I've never seen any dust spots in photos. Furthermore, I took out the A55 mirror months ago and I still haven't seen any dust on the sensor...
However, on my old Sigma SD14 dust was a real problem--which is strange, because the SD14 has a removable IR filter in about the same location as an SLT mirror. You would think that the SD14 would therefore be as resistant to dust as the SLT cameras, but it isn't. On the other hand, Sony can shake the sensor to remove dust and the SD14 cannot...
That should not be the case. I sent my SD14 back to Sigma to be cleaned and it was returned without any dust spots. Unfortunately, it wasn't long before the sensor got dusty again...
There are cleaning kits. The first step is to try blowing the dust off the sensor. You can try one of those lens cleaning blowers, but a better bet is compressed air (buy a can specially made for photographic use). If that doesn't work, then you have to try some type of special brush to wipe the dust off of the sensor. I'm sure there are videos on YouTube which show how to clean your sensor, and what tools you need...
As your image suggests, shooting at f/22 will show up dust spots more than it would at wide apertures. You simply can't get away with this fact, and have to clean the sensor, regularly. And the more you use zoom lenses, or change lenses frequently, while shooting in dusty environments, the more you can expect this problem on any camera. If you shoot primes, and rarely change lenses, this would be less of an issue.
Do as the link above describes. Keep in mind to check the translucent mirror for dust also.
Don't be shy with the sensor, I was cleaning my a57 regularly with a blower, brush and lens pen (gently) with no I'll effects. Best of luck.
The dry uncocked rice works, cleaning the sensor with compressed air is strictly off limits and if it's fungus it won't work anyway and you have to find a solution fast.
For the camera AND the lens(es).
Amazing!
