Barrie Davis wrote:
Jeff wrote:
TheSunsAnvil wrote:
Intuitively I would have thought that the view angle (or how much of the scene we see) is a fixed function of the sensor size vs. focal length, somewhat synonymous with magnification, yet there are Xmm lenses which are designated as "wide angle" while others are not. What am I missing in my understanding here?
Your intuition is partly right, the angle of view is determined by the ratio of sensor size to focal length. To get a wide angle of view you need a shorter focal length lens *and* that lens has to able to cover the full width of the sensor. That second detail is very important.
For example, suppose you have a 25mm lens. If it could be mounted on a full frame 35mm format camera like the Nikon D800, and if it could fully cover the sensor, then it would be wide angle lens.
Mounted on micro Four Thirds camera
it would be a normal perspective.
Whoops! 'Perspective' is the wrong word here, Jeff.
Lenses do not
have a perspective, as such.
Instead, it is positions in space that have a perspective.... wide angle lenses including more of the available "perspective" within frame, and tele lenses rather less of it...
.... but the perspective of both shots, meaning the size relationships between near and far subject elements seen from the
same point is space, is.... -(pause for effect)-.... identical.
I just thought I'd mention it, okay? ;-)
