Bridges of the Oregon Coast - Rogue River
RustierOne
USA, OR, US
This is part of a photo project featuring Bridges on the Oregon Coast Highway (US 101). My goal is to get different views of these bridges to document not only form and structure, but also the setting and beauty of these engineering marvels from the first half of the 20th century. I'll start a thread for each bridge, and then add photos to each thread in the course of my travels. Others are welcome to add their images at any time. I'll include some information about each bridge, taken from various sources. Any additions or corrections to my descriptions would also be welcome.
My next entry is the Rogue River Bridge, the first of Conde B. McCullough’s six major Oregon coast bridge masterpieces. Completed in 1932 for $593,000, it is named the Isaac Lee Patterson Memorial Bridge after a former Oregon Governor who promoted it's construction. This graceful, 1898-foot (579 meter) bridge employs seven 230-foot (70 m) open spandrel, reinforced concrete deck arches, as well as a number of deck girder sections on each approach. The roadbed is 27 feet (8.2 m) wide, and the structure is 34 feet (10 m) wide overall.
Construction of this bridge utilized the Freyssinet Method of arch ring decentering and concrete prestressing, named after its French inventor, Eugene Freyssinet (1879-1962). This method was developed to compensate for the tendency of reinforced concrete arches to sag and crack after construction due to shrinkage as the concrete cured, as well as from loading and temperature changes. In order to avoid the additional cost of more concrete and reinforcing steel, Freyssinet chose to leave the arch ribs open at their crowns. Here he introduced a system of hydraulic jacks to lengthen the axis of each arch by an amount calculated to compensate for the sag that would otherwise be encountered. Here in the gap produced by the jacks, steel-reinforced concrete was fabricated to key in each arch. Upon removal of the jacks and curing of the concrete, the arches would sag to their designed shape.
The Rogue River Bridge was the first reinforced concrete arch span in America using the Freyssinet Method. Construction required the use of sixteen 250-ton hydraulic jacks from Freyssinet's firm, enough to work with two arch panels at a time. The successful completion of this bridge was instrumental in the development of prestressing of structural concrete bridge members, a common construction practice today.
Like many of McCullough's designs, the bridge has architectural and decorative features including fluted Art-Deco entrance pylons, dentils, ornate bracketing & sidewalk railing, fluted spandrel columns and detailed arched fascia curtain walls. His designs were not only cost-effective and functional, but beautiful as well.
What follows is the only image I have of this bridge at present.
Rogue River Bridge near its south end, viewed looking west toward mouth of the river and the Pacific Ocean
Best Regards,
Russ
We traveled to Gold Beach earlier this summer where the Rogue River Bridge is at and I had an evening that I was able to go and take some pictures of this bridge. There was a fog rolling in so I did not have a sunset to photograph, so I shot black and white because I like the contrasts of the architecture. It is a nice bridge, but I really like the Yaquina Bay Bridge in Newport more.
Thanks for adding your comments and image. It illustrates how weather is part of the setting. I also enjoyed how it shows some of the decorative features of the bridge. If I'm not mistaken, this looks like a shot from the southwest side of the bridge near the boat basin.
Most of the Highway 101 bridges of Oregon are of differing designs. I'll have to take a look at the Yaquina Bay Bridge next time I go through Newport.
Best Regards,
Russ
You are correct. These pictures were taken at the Southwest area between the bridge and the marina. I have seen other older pictures of this bridge from the Northeast area that move the dike further back and lessen its effects in the composition. The next time I go there I will have to try it.
If you make it to Newport Oregon to see the Yaquina Bay Bridge, the Northwest area next to the bridge has a nice road next to it for easy access.
My cousin, Louis Giottonini, built Jot's Resort in the early 1960s on the north bank of the Rogue where it still stands to this day - the first fishing resort of its type in the area. I spent many happy summers there as a kid, and was last there for Thanksgiving 2011. Did some drift boat fishing and snagged a couple of salmon ;-)
Here we are trolling in the bay along with everyone else - the resort is the three large buildings on the left.
Nikko
Thanks, Nikko for the information. So that's where the name "Jot's" came from.
Thanks too for the nice photos above, showing the fisherman's view of the bridge.
Best Regards,
Russ
Russ
Exactly right. Although Jots is no longer owned by my cousins, please excuse a blatant plug for the area. If you like fishing, it doesn't get much better than the Rogue & nearby areas. Always with a local guide (even my cousin uses guides and he's local), you can pull out monsters like this 38lb specimen:
Spring run Chinook salmon, Rogue river, 14 May 2011
but for the purists, take a drift boat trip. I went down the Sixes River, just north of Port Orford, and caught a couple (maxed out in other words) of these:
Sixes River, November 26th 2010
Since you like taking photos of bridges, next time you're in Gold Beach, drive up Jerry's Flat road to Lobster Creek - there's a cool old trestle bridge there which you can see in Google images.
Nikko
Here's a few of photos taken from the west side of the bridge:
View from the west looking up from mouth of the Rogue River showing most of the 1898 ft. (579 m.) length - all seven 230 ft. (70 m.) arch spans are visible
View from west showing north half of the bridge
View from west showing south half of the bridge
Best Regards,
Russ
Some years years ago the state of Oregon recognized the need to protect the steel re-enforcement bars in concrete bridges from further degradation caused by corrosive effects of the marine environment. As a result one of the Oregon coast bridges chosen to have remedial measures applied was the Rogue River bridge. The method chosen was "Cathodic Protection " used to extend the service life of concrete reinforced bridges beyond 120 years. In this method a sacrificial metal (zinc) is arc sprayed on concrete bridge surfaces. Then a constant cathodic protection DC current is applied which then forces any corrosion taking place to occur on the sacrificial zinc, protecting the internal reinforcing steel.
I have wanted to add some more images of this iconic bridge, showing some of its decorative features. These photos were taken on my way back from photographing the Thomas Creek Bridge some 15 miles further south.
View from near south approach on upriver side showing an entrance pylon and a few concrete deck arches
View looking north from near south approach showing two entrance pylons
View looking North showing Entrance Pylon at south entrance
Some fluting and arched window embellishments on one of the south entrance pylons
View looking west toward mouth of Rogue River showing decorative features near entrance pylon
Looking west toward mouth of Rogue River showing railing decorations
Best Regards,
Russ
Best Regards,
Russ
