Mark S Abeln
At midday, in full sun, I usually shoot with my Nikon's Daylight preset, and the white balance of the photos usually look great.
Well OK… they sometimes have a slight cyan cast, and so I will occasionally adjust the white balance in post processing to make them look a bit warmer, or I'll do a manual white balance. But it's good enough.
As I do nearly all my shooting near my home, I've never given any thought to the Daylight preset. It usually works well for me. But the other day I read this thread:
http://www.dpreview.com/forums/post/51975303
where the OP wrote the following:
What works for you? I'd be curious if there is a clear pattern or unusual conditions that greatly alter white balance.
My initial gut reaction was that Mr. Peterson must be wrong, or that his computer monitor must be too blue. But I reconsidered when other folks say that they use high color temperature settings routinely. Although now it seems obvious in retrospect, typical midday color temperatures increase with latitude — the lighting is more blue and less yellow, since the sunlight becomes more attenuated and the coverage of the blue sky is larger.Member said:I was reading Bryan Petersons' Understanding Exposure for the first time, & was surprised to read that he uses the "Cloudy" setting for the majority of his outdoor photography.
- What camera do you use?
- Where do you live?
- What white balance settings do you use at midday?
- What software do you use, or do you use in-camera JPEGs?
- Do you have any other observations on daylight shooting?
