Winger67 wrote:
I'm finally getting around to converting my negative 35mm and APS film to digital. I have a Nikon LS-4000 ED, VueScan, Lightroom 4, and Photoshop CS6. What would be recommended workflow? Should I scan everything unretouched by VueScan then import to LR4 and do my grain and scratch removal there? Haven't looked too much into it yet but was hoping to get pointed in the right direction.
I use a Canon FS4000 for my film scanning and Vuescan and this is what I do.
1- First, I accepted not everything was worth scanning. It would have also taken much too long to do. Not worth it.
2- In Vuescan I generally scan my negatives at the default settings after choosing my film type on that settings tab. You need to double check you are happy with the way the film type profile works for your particular film. It may not produce accurate results for whatever reason. Try another if that's the case. Essentially what I am looking for is no unusual color casts and that the contrast gives a slightly flat looking picture to preserve whites and blacks. For negatives 0 for both the black and white level will essentially preserve all the detail you see in the film under a loupe but it will yield an extremely flat picture that will require a bit more work. That may be worth doing for overexposed images. I also make sure Vuescan has nailed the focus as it doesn't always for certain film or frames.
3- With canned air I blow film in holder, then brush with a super fine bristled painter's brush, blow again.
4- Scan with infrared dust removal enabled and for 16 bit tifs. Not sure if your Nikon has infrared dust and scratch removal but if it does definitely use it and figure out which setting reasonably gets rid of dust and scratches while preserving detail/sharpness. I don't use any of the other editing options like grain, etc, as I think they are lousy, but results may be different with your scanner. And of course no sharpening.
6- Examine scanned frames at 100% for proper focus and to see how effective dust removal has been. For more important frames or strips of film I wet clean the film in 99% alcohol. First I dip for around 15 seconds, then I take out and gently wipe both sides with a wet 100% piece of cloth and then do a final dip in another tray of alcohol, shake off excess and hang to dry. I then scan them again. Each cleaning I use a different strip of cloth and replace the rinsing tray of alcohol frequently.
7- For really special images I may do a multi-pass scanning to reduce noise but for my scanner it ads a lot of time.
8- I am now using Lightroom 5 as my primary photo editing app with Paint Shop Pro X5 as my external editor and I get fantastic results. I couldn't be happier. For noise reduction I use Neat Image. I also do not sharpen in Lightroom.
I think I covered most everything. If you have any other questions feel free to ask.
