EinsteinsGhost
I ask for illustrations because talk is cheap.Biggs23 wrote:
My needs are simple: I need to be able to create beautiful images of my clients that also serve the purpose of differentiating me from my competition and those who would seek to be my competition but are not (soccer moms). I do that by employing a variety of photographic techniques including advanced OCF, great exposure, and a wide range of photographic choices including everything from extremely shallow to extremely wide DoF. As such, I need the tool(s) most capable of allowing me to do those things.EinsteinsGhost wrote:
I'm asking you. Illustrate your needs for me please.Biggs23 wrote:
Whether it's negligible depends on who you ask. However, as for 'needing' something, NO ONE 'needs' photographs. No one 'needs' this format or that one. Instead, they 'want' it. They want this look or that look, this angle or that angle.EinsteinsGhost wrote:
Of course, and the advantage is negligible. Hence my reasoning against the commonly held idea of "NEEDING" something like f/1.2.Biggs23 wrote:
Which can be controlled even more with a larger sensor.
You think that you did.I did.Stick with the argument made, when responding to one.You're stating something alright, but I wouldn't go so far as to call it 'simple' or a 'fact'. Are you aware of how DoF actually occurs?Simply stating a fact. Do you disagree with it? If so, I would LOVE to hear more on it, rather than thinking apples and oranges and going bananas with them for irrelevant arguments.Not an apples to apples comparison and you know it.You do realize the point I made, that the same lens on FF would have a deeper DoF at the same distance, no?You've demonstrated the one place where the add DOF of a smaller format can be an advantage: close up/macro photography. At a larger distance to subject, the more shallow DOF of FF can be very welcome.The following image has no value but only to demonstrate DOF, which is barely "a fly deep":
I was very specific with my question. Please try again. You will not be responded you if you try another go at a run around on this.Except you're ignoring the fact that when you standardize FoV you get more DoF with smaller sensors, not more. I know it's convenient to your argument to ignore that reality, but that doesn't make it forgivable.Use DOFMaster or iDOF Calc and get back to me regarding DOF achieved from a 135mm f/2.8 lens used on APS-C and then on FF body, from minimum focusing distance (assume 1m).
Which would lead you to my response (highlight just below), a point you two are arguing against.
"And that is APS-C. The same lens on 35mm sensor will actually have a deeper DoF due to a wider FoV."
That is my point. I'm trying to investigate this fascination with f/1.2 and f/1.4 lenses, however, much less at ultra-wide and wide angle FLs.Necessarily, actually. For portraits, landscapes, or whatever you very well may choose to shoot closed down a bit but you can always do that on FF, too.Not necessarily, actually.True, macro photography is the one area where smaller sensors have at least some advantage.But that is besides the point. Even for portraits, and landscapes, you will choose to not shoot wide open for similar reasons.
Would you die if you didn't want photography? Excuse me for asking for logical responses.Really? You NEED photography? You'll die without it?Not to me. There is a rational side that must be weighed in as well and especially when we're discussing such things as sensor size, apertures, focal lengths and expecting observable results out of it.As covered above, ALL photography is about 'want' over 'need'.Perhaps the most convincing argument you may have made. Its all about "want"?If you wanted that focal length and aperture? That's a very confusing question, perhaps you meant it to be rhetorical?Why exactly would you need 50mm f/1.4 on FF?
And I didn't mind providing the information you asked for even though. But with my questions, you show up with an attitude demanding "what do you want to prove"?No, it was because I genuinely didn't know how big it was. As for backing something up I see no need for the poster to provide one of HIS photographs to back up a point. As long as SOMEONE'S photographs exist to prove the point, and they do, there's no need to be poster specific, just as I posted proof in the form of someone else's video in a previous thread.It would prove several things. For example, you wanted me to provide measurements of a system. Was it to prove something? I'm simply curious to see the point of super fast wide/ultra wide lenses especially when a person is relying on it to make a point. Its not a stretch to expect people backing up their points with photographs in a photography forum, is it?Biggs23 wrote:
You're asking him to provide a photograph but if he did so, then what? What would it prove? Besides, even if he did you'd probably ignore it entirely as you did to the 'proof' photograph that I provided in previous thread a week or two ago. The only reason you ask for a photo is so that if he doesn't provide it you can say 'well, it must not really matter because you haven't done that', even if the concept itself is 100% valid.EinsteinsGhost wrote:
Provide me with a photograph you've taken with such combination so we have something to work with.joejack951 wrote:
Yes it is, and you get even more control with FF. Try matching a 24mm f/1.4 on FF (a combination that even wide open has a good amount of DOF) with a crop camera.
Is it a stretch for you to demonstrate why you make a point that you do?
I'm asking for something. That isn't avoiding in my world.You are indeed avoiding the point.Avoidance.Same story as above.Give me an example.There are times when wide open at f/1,4 on full frame (or wide open at f/2.8 or f/4 depending on the lens) that I wish I had less DOF, or am happy with the amount I have. Using an APS-C camera would then mean that I'd have more DOF than I desired.
Parroting something isn't a substitute for discussion.I have been, and the more discussion occurs the more it becomes apparent that the above statement is true.You can choose to. Or, you can choose to discuss.Right, which we've done at length. MILC and similar have a size, weight, and some macro advantages. FF has all the rest. Should we just leave it at that?This isn't about trying to make you happy, or sad. This is about discussing pros and cons of systems.Why is it so hard for you to understand that, as perfectly illustrated above with your pictures and question about necessity of a 50mm f/1.4, just because you are happy with your APS-C results doesn't mean that everyone else has to be?
