Andrew Curatola
I think my R3000 drop dead on me. So I'm looking to get a R2000. I'm just curious as to what is the capacity of the R2000 ink carts.
Andrew
Andrew
In a 15sec search using Bing I got the product page at Epson which says 17ml.Andrew Curatola wrote:
Andrew
Have you tried InkRepublic i-Remove kit?Andrew Curatola wrote:
I lost the use of my Vivid Magenta channel. I'm almost certain it is not a clog. If I do a nozzle check the space on the printout where the Vivid Magenta suppose to be is totally blank. Not even one dash is showing. I did approx. 20 to 25 Head cleaning and the Nozzle Check still shows a blank space where the Vivid Magenta should be.
I cleaned the head, did a flush using the Jon Cone method and the Inkjet Cart method to no avail. I injected cleaning fluid thru Vivid Magenta channel and the cleaning fluid is absorbed on a piece of Scott Towel I have underneath the movable head which I think tells me there is no obstruction in the channel.
I've had the printer 2 years come this June. I've printed out between 5 to 10 - 7" x 10" photos every day for almost 2 years so I got my use out of it.
I have cleaning fluid in the Vivid Magenta channel right now, If by tomorrow I still have the same problem, I'm not going to try and have it repaired I'm just going to throw it out. I got my use out of it so I don't feel bad.
I was thinking of getting a R2000 but it only holds 17m (btw thank you for the info on the 17m cart). I think I'll just get another R3000 even though there are not too many places that still have them. In fact Epson shows out of stock which I think means that they are ready for a new batch of photo printers. BTW, to me the R3000 is a great printer.
Andrew
Andrew
