netguru717
Leading Member
Which values do you use for the USM ?
I guess different ones for dfferent kinds of photos, objects in it ?
--Which values do you use for the USM ?
I seldom use USM but when I do I apply it to the Lightness channel in LAB mode and the Amount varies widely depending on the softness of the image but ranges from 100% to as much as 500% in some extreme cases, with Radius of typically 0.3 pixels, Threshold almost always at 0.Which values do you use for the USM ?
Hi. I "borrowed" these values from Shutter, who posted them in a sharpening thread several months ago.How do these terms match with PhotoShop?
ie
PSP = PS
radius(100) = radius (250)
strength(500) = amount (500)
cliiping(100) = threshold (255)
Here is a good web site tutorial that may answer some questions and gives good advise.Which values do you use for the USM ?
A hint: sub-pixel values at under 100% crisp images without adding visible artifacts. When reducing images to web-size, 0.3 pixel radius by 80% is my rule of thumb. Leave Threshold out of it.Which values do you use for the USM ?
http://epaperpress.com/psphoto/index.html
K
