Olympus E-10 review
Ed77340
Forum Enthusiast
HK
I have used Fuji S1 Pro for quite a while, sold it couple of months ago as I was planning to upgrade to S2. Came across an used E10 with the mapping firmware feature and 128MB SM card for only $500, so decided to give it a try in the interim. I am quite impressed by the image quality and it stood well against the S1 images. I like the fact that I don't need to worry about dust on the CCD like the other Pro DSLR. I may hold on to this a lot longer and wait for the S3!
There are some obvious limitations with this camera, but if your application does not require higher shutter speed and you can live with the long write time, then this DSLR is a real bargain especially if you can pick one up cheap. So far, I have no problem with using the IBM 340MB microdrive and did not experience any focusing problem. I do miss the wide angle limitation and I can't use the same Olympus 0.8X wide angle adaptor for my Olympus C-2100UZ! I don't have the FL-40 flash but I have no problem using all my Nikon flashes in Auto Mode while putting this camera in Manual mode.
Problems:
No problem so far.
