paulzoom
Forum Enthusiast
Ihave a Fuji S1 Pro and need a ND filter for outdoor flash. If you had to choose just one filter to buy, would it be the two-stop or 4-stop?
--Ihave a Fuji S1 Pro and need a ND filter for outdoor flash. If you
4-stop?
It really depends on how much ambient light you have available and> how much DOF you want. You should be able to use the "sunny f/16> rule" to help you out.> > ex#0: If you are using iso 100, the "sunny" rule predicts an> exposure of f/16 at 1/100 (about 1/125 sec.) at noontime in full> sun.> > ex #2: A 2-stop ND filter will let you set your camera to f/8 @> 1/125 and> maintain the equivalent exposure, and> > ex #4: 4-stop ND filter would have you at f/4 @ 1/125 for an> equivalent exposure.> > If you are shooting in open shade, evening or morning, your mileage> will vary.> > Now, to the question of fill, if you wanted your fill about 2 stops> under ambient, you'd be able to set it to f/8 in each "sunny"> example, and be right in line. So you should know that you need a> flash that can make at least f/8 light at the subject distance &> ISO 100.> > Hope that helps.> > Regards,> > Matt> > > Ihave a Fuji S1 Pro and need a ND filter for outdoor flash. If you> > had to choose just one filter to buy, would it be the two-stop or> > 4-stop?> > --> Matt
I am not quite sure what you are trying to do. I asume you are trying to keep the camera within the flash sync rate and a f/stop of around f8.Thanks for the reply. I guess my dilemma is that I don't know what
my flash (an SB-24) can handle. If it can handle f/8 on a sunny day
I'm set. But if it can't I would have to go to the 4-stop ND
filter. However the problem, is what if it is 1/125 at F/11 and I
use a 4-stop ND filter which would bring me all the way down to F
2.8 which would be not enough depth of field.
I guess I'm saying that ideally, they would make a 3 stop ND filter
which would be perfect. I'm wondering what most Fuji S1 owners are
using for ND filters and what flash they are using.
coltrane wrote:> > Thanks for the reply. I guess my dilemma is that I don't know what> > my flash (an SB-24) can handle. If it can handle f/8 on a sunny day> > I'm set. But if it can't I would have to go to the 4-stop ND> > filter. However the problem, is what if it is 1/125 at F/11 and I> > use a 4-stop ND filter which would bring me all the way down to F> > 2.8 which would be not enough depth of field.> > > > I guess I'm saying that ideally, they would make a 3 stop ND filter> > which would be perfect. I'm wondering what most Fuji S1 owners are> > using for ND filters and what flash they are using.> > > I am not quite sure what you are trying to do. I asume you are> trying to keep the camera within the flash sync rate and a f/stop> of around f8.> > If the sun is very bright it's also likely to be harsh too. A N/D> filter is not going to fix that. You might be better trying to find> some shade or use a large brolly if no shade is about. The would> solve both problems. Plus a little fill flash on top!> > Hope thats helps> Alex
--I am not quite sure what you are trying to do. I asume you areThanks for the reply. I guess my dilemma is that I don't know what
of around f8.
Hope thats helps
Alex
Neither would work unless you have a very powerfull flash gun. it is true that you open the lens and get a larger lens opening but the light from the flash has now been reduced by two stops as well so it is (except for depth of field control) a waste of time and it can only cause more problems.Ihave a Fuji S1 Pro and need a ND filter for outdoor flash. If you
4-stop?
coltrane wrote:> > Ihave a Fuji S1 Pro and need a ND filter for outdoor flash. If you> > had to choose just one filter to buy, would it be the two-stop or> > 4-stop?> Neither would work unless you have a very powerfull flash gun. it> is true that you open the lens and get a larger lens opening but> the light from the flash has now been reduced by two stops as well> so it is (except for depth of field control) a waste of time and it> can only cause more problems.> I have an SB24 and it has a guide number of about 110. That means> that at ten feet I can use f-11.0. The exposure to fill the shadow> side of the subject (on a sunny day) that needs the fill, would> 1/125 @16. The flash would be good to about 8 feet.> With a 2 stop ND, the exposure drops to 1/125 @ f-8.0 and the flash> is now good for half the distance which is 4 feet. As you can see,> you are better off to not use the ND filter and get a much more> powerful flash unit.> Rinus of Calgary
sun.
1/125 and
will vary.
ISO 100.
Hope that helps.
Matt
4-stop?
Matt
