Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X) review
lochunyip
Member
HK
Select it for:
- low image noise
- compact and good looking (you may say I'm novice, but I think I have artistic sense and appreciate elegant design)
- excellent flash metering (Nikon flash overexpose very frequently, you may able to set this and that to avoid, but don't bother me)
- good auto WB (Nikon always greenish under shading, you may able to set this and that to avoid, but don't bother me)
- good user interface (personally I hate those cameras having all the settings require "holding one button and rotate the wheel at the same time", but not making use of the big screen)
- PictureStyle is useful
- decent result without post-processing
- very good software bundled
- small, light and fast charger
Hate it for:
- few choices for EF-S lenses start from 17 or 18mm (Nikon has 17-55, 18-55, 18-70, 18-135, 18-200; Sony has 18-70, 18-200), but Canon always say it has a lot of lens choices.
- no in-body image stabilizer (I know the advantage of in-lens IS, but also have in-body one should be no harm)
- back focusing is common (now I learnt that the best photo system is back-focusing system, mine back-focus from 18mm to 30mm with kit lens)
- LCD reflects light, so it's hard to read
- no spot metering (if you say it's not useful, please don't use it on 5D or 30D, don't use it)
- LCD easy to be scratched (Sony is excellent in LCD)
- not comes with lens hood and lens bag (Nikon has)
Problems:
Back focusing from 18mm to 30mm when used with kit lens
