Canon PowerShot TX1 review
Terry Wong
New member
HK
I mainly use TX1 to shoot video on my kits, I found the 1280x720 long play is good enough which can give you around 1hour by using 8GB SD card. Photo quality is very good thanks to Digic III. But most of the time, I use it to shoot video, great fun.
The other feature is zero distance micro lenses, can shoot photo with 0cm, it's amazingly good! Also, WB is very accurate.
Problems:
Battery life is a bit problem, need to bring a spare battery if you are out for one whole day.
For next generation TX1, should have wider lens, something like 28-300mm instead of 39-390mm
