Fujifilm FinePix S9100 / Fujifilm FinePix S9600 review
Sma11fry
New member
Cardiff, UK
Flexible, intuative versitile. Why would I want a 6Mpixel DSLR for twice the money? Believe me Jessops tried. Do I want to look the part? Impress the other photographers?
No -"I want them to look at what I produced to do that," I explained.
The top and bottom is, functionally this camera has everything, so the question is, is the lens upto the job? Well yes and no. It does everything adequately. Unless you plan to spend more on your lenses than the body, and you can't run to several grand. Buy this. There isn't enough of a picture quality improvement in a £650 camera body and two 14-70 70-250 kit to match this for £299.
As for results, you can use a box brownie if you have an eye for a shot, if not buy postcards, save yourself the money.
Problems:
12" between battery warning, and camera switching off entirely. But the MeHy and NiCads work then they don't. Otherwise none. Flash is naf buy a slave and give yourself the option of modelling, mind they work with Digital cameras mind, old ones don't like the two burst - shutter on second.
