agree that the 18-55IS is great value for money, and very sharp in the WA range (even full open). I tested four of them from different batches and optically they were very close, so in general sample variation should not be an issue.Shorthand wrote:
Honestly, at the wide end the 18-55 is pretty good. Before you go investing in new hardware (though none of us can say that the 17-55 f/2.8 is a bad investment), it would be wise to post some unsharp shots (100% crops) from the kit lens here. Often its technique or a bad copy that needs replacement or service and not the lens design.
Problem is, on many Rebels (and maybe also xxD series) the 18-55IS has a tendency to frontfocus, so you need to use Liveview or stop down for best results. When focused correctly, sharpness is very close to the 17-55. Also, the 18-55IS has a naughty flare problem that is a bit unpredictable and almost impossible to correct (local areas with lower contrast when used in contrasty lighting). Because of that I purchased 15-85IS instead (much more expensive and heavier, slightly better color and contrast, not much sharper but: no flare problem).
