R
Ron Reznick
Guest
That kit sounds as if it could be a good setup for you, Dave. One nice thing about the WD JBs is that if you decide to make the change to SCSI later, you can clone your drives over to the SCSI for OS/Software and working space, then put the JB drives into Firewire cases and use them for local archival. If you are on a budget, I'd really consider the Athlon XP -- the performance of the top Athlons are equal or superior to all but the very fastest Intel CPU at a significant price benefit, and in a great many working applications the top two Athlons equal the performance of even that expensive Intel flagship. The rest of your proposed setup sounds like a very good foundation. This will be far more than an incremental improvement -- it's likely that you'll see a five-fold performance increase.
If you need help acquiring, assembling and configuring, let me know.
Ron
Ron Reznick
http://digital-images.net
http://trapagon.com
Ron
--Thanks for your help, Ron. I don't have the kind of money to spend
for the setup you have (just your hard drives and controller are
over a grand.) When I first started kicking around the idea of a
new system, I thought about SCSI, but I'm trying to avoid the
noise, heat, power, complexity, and especially cost, and was hoping
I could get by with 2 WD JBs instead. I'm also looking at a P4 2.53
on the new Intel MB with the 845PE chipset, since I want the fast
333 DDR while avoiding RAMBUS. Dual processors again sound a bit
complicated and expensive for me right now. Ditto RAID. I was also
considering 1 gig of DDR CAS 2.0 RAM, a Matrox 550, and the
assorted CDRW, etc.
It sounds like this setup could give me a big boost in most of
these imaging tasks. I want to be sure I'm not throwing money away
on only an incremental improvement. Any additional input
appreciated.
Thanks to all for your help.
Dave
Ron Reznick
http://trapagon.com
