John Buchmann
Leading Member
I searched this forum and i don't think this method has been mentioned. I just discovered an easy way to increase detail/contrast in any photo without unsharp masking.
I'm calling it "contrast lines" (similar name to "contrast mask" which i find really helpful)
Try these easy steps in Photoshop and see if it doesn't improve your image:
Note: My tests are with a 5 megapixel image. You may have to adjust the settings for a lower res image.
1) Duplicate background layer
2) In the duplicated layer, run the "Glowing Edges" filter in Filter--> Stylize menu.
3) I used these settings for a 5 mp image:
Edge Width: 2
Edge Brightness: 6
Smoothness: 10
4) Go to Image--> Adjustments--> Desaturate
5) Go to Image--> Adjustments--> Invert
6) Go into Curves and drag the right end point down half way. Everything white will change to 50% black while the black stays the same.
7) Change the layer mode to Overlay.
8) If necessary, decrease the layer opacity to suit your taste. I left it at 100%
Done
Please let me know what you think!
John
Edge Width: 2
Edge Brightness: 6
Smoothness: 10
Done
John
