nelsonal wrote:
Your field of view is tied to the same ratio as your focal length. So 55/18 is roughly 3x so you would need to be about three times further from your subject to achive the same framing (of your subject).
However unless everything in the frame is at the same distance, Everything else in the frame would be framed differently since your distance away from the other objects did not change by the same ratio. As an example. Let us imagine you were 6 feet from a person with an 18mm lens. To frame the person in the same way you would need to back up 12 feet with a 55mm lens. If there's a tree 6 feet behind the person, you're twice as far from the tree, so less of the tree will show (if there's a hill a mile or so behind them both, considerably less of it will show since the relative distance to it hardly changed).
I read that but I don't know if I fully understand, maybe if I include an example it might help.
Would the lens be good for everyday shots of dogs and kids playing in a small backyard?
How far would I have to be from a subject if I wanted to do a shoulder up shot with the 55mm?
