Greynerd wrote:
Member said:
shah123 wrote:
Thank you guys for all the responses. I really appreciate it.
Looks like you guys don't seem to be bothered by the fact that the size of the sensor causes a crop factor of 2x and effectively doubling the lens mm. Maybe I should have mentioned that I needed the lens to mainly take pictures of my 9 month old twins - that is - for indoor photography. So if I get a 50mm lens, it would be like having a 100mm lens and that is quite a bit of zoom for indoor photography. Am I missing something? My understanding is that when I would plug in a 50mm lens, and look through the LCD, I will see way closer than I would expect from a 50mm lens. Is that not true?
Thanks again guys for your support and pardon my ignorance if I am asking totally stupid or trivial questions.
I have a 45mm Olympus 1.8 and I find that rather narrow for the grandchildren when they are moving. I find the 30mm Sigma f2.8 easier to use and one I use more. Whilst your twins are not rushing around 50mm will be fine if you can stand far enough back but 50mm will be tight indoors as it is 100mm equivalent. As your twins become more mobile manual focus may be a problem if you use a legacy lens with an adapter.
I believe you can hold the flash on the EPL-1 as with the EPL-2 to bounce off the ceiling and I use an EPL-2 with the slow kit lens bouncing the fairly powerful flash which I find can give excellent results indoors, better than the fast lens but of course with less isolation.
