I used the MCON and set the camera to f11 in order to get maximum
DOF. Placed the items in a box lined with white paper--sides cut
out and 'windows' lined with opaque paper. I used a desk lamp which
I shone through the opaque paper as a light source. My aim was to
reduce reflection and glare from jewelry surfaces. I tried several
'backgrounds' (black felt, white styrofoam and what I finally ended
up with was a flat, white foam backing.) It gave the most pleasing
results...to my eye anyway.
I am trying to work this out with the least possible outlay. I'm
getting paid in free advertising, so don't want too much out of
pocket expense upfront. Have gerryrigged equipment.
Any suggestions for getting a more natural tonal balance? What
other backgrounds might I try? I could do some softening in PS
after the fact, but that probably won't do much.
Looking at the pics, the following questions came immediately:
1. Why are you getting such high levels of noise, in first place,
in a picture that is already down-sampled in size? What camera
settings are you shooting for?
2. Do you intentionally expect to have such bright, almost "burned"
white areas as part of the final effect/visual impact? If that is
not the case, then it may be interesting to try a more conservative
approach towards high-lights exposure and look for a more natural
tonal balance (IMHO). Use the E10's dynamic range to your advantage.
I can not see almost any detail behind the feather...
Kindest regards,
Ferenc
Ok, I've got to learn jewelry photography. I have a job taking a
jewelry shot that will become a cover for a coupon book in our
area, IF I am successful! I have been practicing today. Made an
opaque box in which to photo the pieces to cut glare and
reflection. Used no flash, just a desk lamp shone on the box from
outside. Here they are...fire away!!
This one I Neat Imaged
This one is not "Neated."
The jewelry is mine and not scratch-free, but other than that, how
did I do for a first try? Suggestions much appreciated!!
Beth
Olympus E-10, TCON, MCON, WCON and Fl-40
Gallery:
http://www.pbase.com/galleries/cokids
Gallery:
