Hello everyone!
First off let me say that this is my first post on the forum so please let me know if I'm doing anything wrong or if this is int he wrong section or something
I've been roaming the forums for a little while and I've picked up photography in April so I'm still fairly new to this. Please feel free to check out my flickr.com/klweng
Anyway, I'd like to review a product I got on amazon for 5 dollars. It's a knockoff brand of Gary Fong's pop up flash diffuser:
The build of the device is well, what you would expect from a 5 dollar contraption. It's fairly solid actually, but the plastic has little bits than can be pulled off, kind of like what happens when you're building models and have to pull the pieces out of a tray. Overall nothing to complain about for 5 big ones.
As for the photographic value, below are some comparison shots for you to decide for yourself, some real dorky pictures of myself.
These were taken on my d3100 and 18-55 with a hood attached. ISO 200 and no exposure or flash exposure comp. I took this near a wall to emphasize the typical shadows that are cast behind subjects. By the yellow gel, I mean I used the yellow attachment rather than the white one. The lighting in the room was dim and yellow, which is why I tried the yellow gel so as not to introduce a white light in a yellow ambient light environment.
My impression is that the device does not seem to be softening the light much or at all. What is clear however, is that it is working pretty effectively as a stoffen and scattering light is many directions resulting in the softening of shadows. The shadow behind me is most definitely less emphasized and the shadow from the lens barrel is basically gone. I think this alone is worth the five dollars.
Used in conjunction with some flash power adjustments, I was able to get the following.
This was show at ISO 800 instead with my exposure comp set at +1.3 and my flash comp set at -1. Also this was taken with the yellow gel. I feel the result is quite decent. Obviously, bounce flash would be preferable, but until I can scrape up the funds for that this will have to do for now and I'm quite satisfied for the price.
I know some of you will say that a piece of paper or a notecard will yield the same if not better results. I realize this, and at the price of the genuine puffer, I'd never pay that much for a bracket and plastic (with no gels might I add), but this was 5 dollars and more elegant than a paper solution so please don't flame me
I hope this is useful to some of you
Thanks for reading!
Kevin
Loading…
www.amazon.com
Kevin
