artbyjustinmoe
New member
- Messages
- 1
- Reaction score
- 0
The print shop I use utilizes photo paper on a roll. I have tried sandwiching the prints with heavy items, ie: books for up to four days and they are still not flattened. Any suggestions?
Get a tube and roll print onto the tube backwards from its current curl, leave it overnight. Be carefull not to tear up the edge you are starting with on the roll.artbyjustinmoe wrote:
Decurling is the only solution, trying to press it flat is only going to work if you have a few years to spare. As jtoolman points out, the roller blind method works. The professional D-Rollers work better and are easier to use, but even the small 24 inch versions are in the US$250 range.artbyjustinmoe wrote:
That's why I only use A2 sheets on my 4800. It has a roll adaptor and can use rolls but I think printing is tricky enough already without curling added to the problems.Hugowolf wrote:
Brian A
Why not post an image. I would be interested to see what you used at the edges, but softer plastic doesn't sound like a good idea.svinto wrote:
I´m realy new at this forum. An other thread regarding curled print show some homemade products. It took me a while to find a construction similar to d-roller. Ive made it whith a softer plastic and different size at the metalpipe. It´s also very important that the ca 1mm tape/stripes are placed at both sides.
If you are interested in my solution I can send a picture. I can also send an exampel whith a low cost.
The desk top printers such as the R2000 and R3000 have roll feeders that only take 2" core rolls. To use 3" they would have to have designed them quite a bit bigger.Craig wrote:
I cant figure out why epson makes a 2" roll paper. That has to be a bugger to flatten. Why not 3"?
It doesn't work with heavier stock. I have tried similar materials., and with 300 gsm cotton rag you end up with compression creases from the leading edge.svinto wrote:
Hope this link will take you to my tips for this issue
