Guys,
Following so many threads about D600 dust issues I wanted to contribute from my experience with the issue, I have already mentioned few times in previous posts my situation (which is not bad) but this is to sum it up after 2,000 clicks I reached today.
So - as many others when I first bought my D600 I had many spots (dust and oil), I have decided to let it be as is for a while (it didn't bothered my images, only my mind). after 700 I wet cleaned it myself (using CopperHill sensor Swipe), once cleaned I confirmed with the loop and test shot it was completely cleaned.
600 clicks later (1300 in total) I rechecked and found more spots (although less), blower wasn't enough to clean it so I had to wet clean it again.
today I reached 2000 clicks so I have decided to celebrate with checking for spots again, took a shot and found around 7-8 spots only, went with the blower, test shot, 1 annoying spot left, blower again, same annoying spot - looking with the loop - can't find it - err...I was suspecting the camera so much that I forgot to look at the lens, than I decided just to look at the glass on the mount side and sure enough, a nice smear on the back of it, I cleaned it and (70-200 at the edge of the glass - not sure it's easier than cleaning the sensor
) took a test shot - spotless...so I had only like 6-7 pure dust spots which I think is normal, and in a reduce dust/oil spot trend...hope this help to some folks.
