viking79
If you haven't seen, the Rokinon 8mm f/2.8 fisheye lens, they have it in NX mount. This is the new very compact Samyang 8mm f/2.8, not the older SLR version that is 8mm f/3.5 and significantly larger (but might avoid the color cast at the corners).
I am seeing magenta corners/sides on my NX20 as they show up on the NEX 7 as well. Might have to use corner fix to correct that, and one side on mine is worse than the other so it might be a slight alignment issue too.
The lens looks sharp, will show some samples a bit later when I get a chance to take some.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Eric
