R
Roy Dankman
Guest
Checking the Epson web site and the instruction booklet I see pn letter sized paper mentioned. Does the C-80 work with paper longer than 11"?
Thank you
Roy
Thank you
Roy
--Checking the Epson web site and the instruction booklet I see pn
than 11"?
Thank you
Roy
Hello Tom,C80 can use paper that is 11 inches wide and up 44 inches long.
Set paper size after selecting 'user defined' in paper size dialog.
Hello Roy,Checking the Epson web site and the instruction booklet I see pn
than 11"?
Thank you
Roy
--Hello Tom,C80 can use paper that is 11 inches wide and up 44 inches long.
Suggest you check your specifications again since I believe the C80
maximum paper width is 8 1/2 inches and will print on less than
this size due to margins. I have NOT used the longer paper,
however; I believe the 44 inches is correct.
Vernon...
http://www.pbase.com/vrain
