Since some time ago, I've decided to switch my Canon gear over to an M-based system. To be honest, I'm not a Leica affictionado, but I like the M-system because there is a big choice of lenses from different manufacturers, and with the mirrorless system, more and more camera's, also from different manufacturers, will be able to use M-lenses in the future.
But, there is the catch.
I've often read that using an M-type rangefinder requires 20/20 sight. I don't have that; in Europe we measure in percentages, where 100% is equal to 20/20. My sight is only 34% after corrections. If someone with 100% can see something at a distance of 10 meters, then someone with 50% sight has to be at 5 meters to see the same; and so on.
At the moment, I use the Ricoh GXR-M, which has focus assist, and enlargement. I can focus this camera very well, even when only using the enlargement. I set it so the "effective" image in the viewfinder would be around 200mm. (So my 35mm is around 52mm on the camera, I set an enlargement of 4, and I can perfectly focus.) Combining the enlargement with MODE 2 assist (high pass contrast highlighting), it gets even easier.
I've never tried Sony's NEX peaking, but I imagine it will be similar with similar results. (I actually really like the NEX-7 a lot; pity about the crap results with sub-35mm M-lenses.)
I can see myself buying a second hand M9 some day, after the M10 hits the market (or another rangefinder appears, or something), firstly because it's full frame, secondly because I think I'd like the rangefinder experience. I can see the appeal of seeing outside the frames, and that sort of stuff.
But... How well can a rangefinder be used by someone with eyesight as bad as mine? Is it something like:
- It can be done, but you will be slow (no problem, I'm slow with the GXR-M too)
- It can be done, but half of your images will be out of focus (only happens occasionally with the GXR-M)
- It can't be done. Better stick to EVF-camera's with focus assist and enlargements.
