Gitzo Traveler versus Mountaineer? Series 1 or 2?
ppronovo
Forum Enthusiast
CT, US
any thoughts or experience for deciding on the Gitzo Traveler versus Mountainer tripod for traveling? Thoughts on Series 1 verus 2 for D800 with 70-200/2.8 beast? Favorite head? Thanks!!!
I went with the Gitzo traveller with a Marking ball head. I upgraded froma D200 to a D800E and have found that it still works ideal in terms of travel size and convenience.
I do own a bunch of lenses 12-24, 17-35, 28-70, 70-200 VRI, 28-300 and 50mm 1.8
It isn't cheap but well worth the size, convenince and stability.
The Traveler folds down smaller, the Mountaineer gives you more options for weight capacity and height.
For me, critically, the Traveler is small enough to fit in a standard international carry-on (20" nominally, but the inside is usually more like 18" long). The GT1542T and a Markins Q3T ballhead should be enough for a D800 with a 70-200 - you might get some wobble if you start using it at weird angles and such.
Just note that the GT1542T is very short (45" w/o center column), and you don't want to use the center column if you can avoid it. I'm tall, but I'm fine with stooping down to the deal with the height for the occasional picture (I rarely use the tripod). If I was using it all the time, though, I'd definitely want something taller - one good option is the Feisol CT-3441T.
Thanks!
I have the Traveler with RRS BH40 head. I shoot with a 5D MkII with a variety of lens up to 70-200mm 2.8. This setup is for traveling light.
For most of my needs I use a RRS series 3 with a RRS BH55.
