gardenersassistant
Yes. All my tests were done with the bare lens. The camera is a G3.A couple quick questions. Have you tested the lens on distant subjects, shooting at 175mm, with no close-up lens attached, at the troublesome shutter speed ranges?
I constructed a test scene with lots of sharp edges. This is how it looked at 45mm focal length. (It looks a bit soft actually, and that mirrors my experience with out of the camera images from the 45-175. I use JPEG rather than RAW, with the settings for sharpening, contrast, saturation and noise reduction all turned down to the minimum. I was initially rather disappointed with the comparison with 45-200 out of the camera images with the same minimum settings. However, I always post process my images, which is why I use those settings, and I found images from the 45-175 responded very well indeed to post processing and after PP looked better, in terms of visible details, rendition of textures and colours, than images captured with the 45-200. This is an impression, not a carefully tested result, but not only does it seem that way to me. My wife is my harshest critic when it comes to IQ, especially the aspects just mentioned, and on seeing the first (processed) non-test images from the 45-175 volunteered the view that they looked better than what I had previously achieved. So I don't think it is just my imagination.)
Here is what the full frame covered in one of the test images captured at 175mm focal length.
These are obviously reduced sized images. I examined the test images at full size (i.e. pixel peeping).
In the series from which this one is taken the camera was on a tripod, and I used a remote (wired) shutter release. The focal length was 175mm. OIS was off. I captured five images at each of the following shutter speeds, with several seconds between shots: 1/320, 1/160, 1/80, 1/40, 1/20 sec. I did a number of other test captures, hand-held and using the tripod, with and without OIS, but many of them were in the context of comparing the 45-175 with the 45-200, and significant proportions of them were outside the troublesome ranges. But that said, in or out of the troublesome ranges, I did not spot any of the problems you and others have unfortunately experienced.
HN2EBThis is where it is easiest to see if your lens has a problem. Firing off three shots at 1/40 - 1/320 each should, if the lens has a problem, be enough for it to show up (in my case, about 30% of the time). It seems possible that a heavy close-up lens like the Raynox might dampen the shakey elements enough to avoid the problem, as does shooting at less than 175mm.
Also, what camera do you use? It generally appears to work well on GH2's and some of the later Olympus models, but not on the G, GF, and sometimes GX1.
If you have a good copy that passes the above test, bravo! What is the serial number range?
Yes, I have been reading about the bad times you have been having. I do hope you can get this sorted out.I was unable to get one and gave up after four tries. I'm putting up with the blur until I buy another camera with a shutter known not to cause this problem, as I do like the lens and use it as my primary walkaround lens most of the time.
http://www.flickr.com/photos/gardenersassistant/
