Olympus 18-180 serial number...?
Brian Steele
Leading Member
St. George's, GD
I'm packaging my 18-180 lens for its trip to repair and I noticed something - there's no serial number on the lens. The little depressed section where the s/n sticker is located on most Oly lenses is completely blank, no sticker present.
Thinking that the sticker might have come off somehow, I tried to check its serial number with my E620, and the E620 reports its serial number is "000000000". Weird. The warranty card says the s/n is 166043987, but there is no way to tie this back to the lens, because there's no serial number on the lens, either physically or in firmware.
I'm just wondering if this is the norm for the 18-180, or is my 18-180 an exception to the rule?
Brian Steele
http://mypages.spiceisle.com/brian
right alongside the Made in Japan lettering
Peter
Mine also has no serial number. A shows a serial number of S/N 0000000. My 18-180 is about 5 years old.
Collin
(Aficionado Olympus DSLR )
http://collinbaxter.zenfolio.com/
http://www.pbase.com/collinbaxter
Life is not measured by the number of breaths we take, but by the moments that take our breath away. (George Carlin)
New Seventh Wonder of the World.
Has it been repaired during it's life? It could be that the circuits have been exchanged then.
I used to have a Macbook G4, which needed motherboard-replacement. When I got it back it had no (digital) serial number anymore. They have special "numberless" parts for repairs, it seems, probably because otherwise the number would actually change after repair... (the printed number on the case sticker was till there though)
Lourens
Ok, so my own is not the only one :0. I purchased my 18-180 only two years ago though. I'm sending it back for repair now because it seems every picture I take with the lens looks like it was shot with a diffusion filter attached.
Brian Steele
I bought mine from Amazon.com -- don't remember when. Its S/N is 166046301.
However, I did have that problem with a Pentax K20d camera. Some camera outfit was selling them at a ridiculously low price -- refurbished with low shutter actuations at $379. I ordered one and it came with a S/N (at least there was a S/N mentioned in the paperwork), but it had a stained sensor; so I sent it back. The replacement camera was excellent. It wasn't until much later that I noticed it had no S/N. I saved the paperwork in case I ever have to have it repaired.
In the case of cameras I learned that they have serial numbers in their software, at least the Pentax cameras do. I forget how one finds them, perhaps by looking at the EXIF info. I wonder now if digital lenses have internal S/Ns as well.
Lawrence
Yep - you can see them if you have a dSLR that can show them. On the E620, if you go into the AF adjustment menu, it will display the s/n of the attached lens (if you think about it, needs some way to identify the lens for this type of procedure).
On my E620 however, it's displaying a s/n of 000000000 for my 18-180 lens.
Brian Steele
Phil Harvey's ExifTool can extract the lens serial # from a photo.
http://www.sno.phy.queensu.ca/~phil/exiftool/
Used it not long ago when trying to find serial #s for lenses stolen during a robbery.
Art P
"I am a creature of contrast,
of light and shadow.
I live where the two play together,
I thrive on the conflict"
