wymjym
I own both and while I appreciate most things about the XS1 the IQ is not one of them.
So….I thought if I already own a lens that would give similar results to the XS1 I could part with the ‘bridge’ and move on.
I have a tamron 18-270, Nikon 28-300 and kenko 1.4tc that I thought might be the most reasonable solution for the ‘test’. Neither lens was thrilled with the addition of the tc and I found that the tamron @ 270mm (+108=378 x 1.5 = 567mm, would focus closer than the Nikon at the longer end and give a bit more magnification.
Long story made short, I ran around a field of flowers for several hours shooting at ‘bugs.
The d5100+lens combo was more difficult to get equal results and there were not enough times that the output was significantly better than the XS1’s.
I will keep what I have and start thinking about composition rather than detail when using the XS1 at fl exceeding 350~400mm.
D5100 + 18-270 + tc 1.4 @ iso 800, f6.3, 567mm, 1/400
This is the closest I could get and achieve focus, 33% view
the d5100 allowed for iso800 files to be as clean as XS1 iso200 files after a bit of PP, still it was too much effort for rather poor results.
the XS1 was shot at iso100 and in good light with no orb inducing light lurking the files work out well.
and the XS1 is just easier to be carefree and have fun with
thanks for your patience
wj
nikonandricoh
wj
nikonandricoh
