As an architect, I keep going to building sites, where i need to
use wide angle shots of buildings from a close range. since I will
not be having lot of space as in the case of INDIA, where some of
my big buildings have come up. even though I stay right now in US.
the actual problem is to capture the whole building(say 100' wide
building from a close range of say 30-40'). I was imagining that
wl-fx9 would help do that..
For this particular problem, you may be better off using a program
to "stitch" several images into a panorama. It has worked for me
in similar situations. The WL-FX9 may help, but only in those
instances when you can't quite get the whole building at the
maximum wide angle zoom without it. For wider shots, stitching a
panorama would work. Note that the lens on the 6900 and 602 has
noticeable barrel distortion at maximum wide angle, which isn't
usually a problem for nature shots but might be an issue for
architecture. This could be worsened by use of the WA converter.
The barrel distortion not only looks bad in architecture shots, but
can make the images more difficult to "stitch."
If you try stitching panoramas, it's best but not essential to use
a tripod. For architecture, it may be better to shoot each segment
at 50mm equivalent focal length [the zoom setting when the camera
is first switched on] rather than maximum WA to eliminate barrel
distortion. Also, you might try taking about three overlapping
photos, side to side, with the camera in the vertical (portrait)
orientation. I've used this technique on construction sites when I
had to get quite close to a building due to equipment and materials
piled on the site.
Mike
