Compared to years ago, OCing is very easy nowadays. As others have said, just make sure you get a better cooling devices to support the increase in temp. And you may have to get a more powerful/efficient power supply to support the extra power needed to OC.How many people have or are overclocking their CPUs?
I want to but need to know wore about what I am getting into.
My system is a Dell Precision 3500 with a Xeon 3565 processor.
Thanks...Alan
Are you in pain now? I've got some Tylenol. . .Well now all of dem hens was a clocking so much for so long the time dat I puts it in anudder roster and den the overclocking it stop so is easy to fixing it with a roster.
May the light be with you
Stop global whining
Stupid should hurt
--Gear: My Lab Lara, cameras, lens, tripod, monopod, cars, MH, motorcycles (yah bought another), helmet, yacht, etc. too much stuff.
I was oc'ing systems when Windows XP was a new operating system..But is it really necessary for anyone but hobbyists and people with special requirements? Ten years ago, just about everyone could have benefited from overclocking, but considering the extra heat (and shortened life of the PC), the noise of the fan, just how worth it is it any more considering Sandy Bridge quad core (even sextuplet core! see: http://en.wikipedia.org/wiki/Sandy_Bridge ) systems. Stock seems pretty darned impressive!
I have a question for the REALLY knowledgeable based on the wikipedia link I just posted. I understand the higher performance processors generally generate more heat than lower performing processor. But is that consistently true? Will, say, an i7 2600S processor that draws 65 watts generate more heat than an i5 2400 model processor that needs 95 watts?
I just purchased an i7 2600s machine on the assumption that it would run cooler than an i5 2400 model. But in truth, I was guessing. Anyone know?
I'm so bright, my father calls me son.
Now that you've judged the quality of my typing, take a look at my photos. . .
http://www.jpgmag.com/people/glenbarrington/photos
Laws of physics suggest that the 65W CPU will run cooler than a 95W one. All the consumed energy must come out somehow, and unless your CPU glows, spins or whistles, the only other thing it may do is emit heat.I have a question for the REALLY knowledgeable based on the wikipedia link I just posted. I understand the higher performance processors generally generate more heat than lower performing processor. But is that consistently true? Will, say, an i7 2600S processor that draws 65 watts generate more heat than an i5 2400 model processor that needs 95 watts?
We were OC'ing systems in the days of 8086!I was oc'ing systems when Windows XP was a new operating system..
True. It took hours to render, and if you botch it or find out that something was amiss in the edit, you go over the 8-hour render again! This considering that the material was just DV or SD, not even HD video of today!It was, at best, an interim cure for systems that needed to be faster.
I was "rendering" a lot of video in those days (prior to the multi-core chips).. it seemed to take FOREVER and oc'ing the computer got it done quicker.
Actually, gamers mostly know that they put their money on the video card, than the cpu. A decent i5 with a strong gpu will give better gaming performance than a 4-core 8-thread powerful cpu that is OC'd.These days, with fairly inexpensive motherboards and multicore chips like the i5 or i7 I dont think overclocking is justified except for "gamers" and "geeks" (no insult intended)..
True. Unfortunately, Intel tend to make new support chips to pair with the new cpu, thus requiring a new m'board. And with the increase in speed, old ddr2 rams, require ddr3. Without a doubt they'll require a ddr4 on the next iteration of cpus!To me, its just as easy to buy a new 'mobo, and a quicker chip (sometimes you dont even need to buy the board, just the chip).
Actually, those monitors help a lot. It does tell you if your cooling system is faulty or has failed. AT times, the fans could stop or full of dust that cooling is less; or the thermal paste already is dry or a dud. I do have to service my system and the ability to see the temps without having to pry open the case is a big thing.For my money, I think putting in extra cooling, and then having to monitor board and chip temperatures isnt worth the effort, and is still just as likely to "cook" your system when you need it most... Like on a Sunday evening, when you cant run out and buy new parts...
Now that you brought it up... so did I... I have often wondered how fast some of my old DOS stuff would be if run on a "modern" system...We were OC'ing systems in the days of 8086!![]()
You can imagine how thrilled I was when machines started to be able to render DvD quality video in less time than it took to shoot it...True. It took hours to render, and if you botch it or find out that something was amiss in the edit, you go over the 8-hour render again! This considering that the material was just DV or SD, not even HD video of today!I was "rendering" a lot of video in those days (prior to the multi-core chips).. it seemed to take FOREVER and oc'ing the computer got it done quicker.
Well, thats a good thing.. I've always noticed the "gamers" that I know seemed like pretty smart guys...Actually, gamers mostly know that they put their money on the video card, than the cpu. A decent i5 with a strong gpu will give better gaming performance than a 4-core 8-thread powerful cpu that is OC'd.
I've tried several different systems using AMD chips.True. Unfortunately, Intel tend to make new support chips to pair with the new cpu, thus requiring a new m'board. And with the increase in speed, old ddr2 rams, require ddr3. Without a doubt they'll require a ddr4 on the next iteration of cpus!To me, its just as easy to buy a new 'mobo, and a quicker chip (sometimes you dont even need to buy the board, just the chip).
'Always in the process of changing, growing, and transforming.'
- Caterpillar
