dv312
http://www.photographyblog.com/news/panasonic_12-35mm_and_35-100mm_lenses
to keep size and cost down obviously
cheers, ;-)
cheers, ;-)
Gotta agree with you there. Concept lenses are just that, concept lenses.The photograph of the lenses shows just F2.8 .... no indication of an aperture range. But then these are just concept lenses behind glass, so we still can't be sure.
Check out the close-up photos of the fronts of both lens. It clearly says f1:2. On both. Nice!http://www.photographyblog.com/news/panasonic_12-35mm_and_35-100mm_lenses
It actually clearly says 1:2.8 on both. I suppose it also implies they are constant aperture.Check out the close-up photos of the fronts of both lens. It clearly says f1:2. On both. Nice!
http://www.personal-view.com/talks/discussion/1974/ces-2012
How much would you pay for 70-200/5.6 for your 5D2?F2.8 at (35-100) 200 equiv.? who could complain. Of course depends on the price, as always.
I'll take the F2.8
Fast enough (esp if its constant 2.8) for me
F2 will be EXPENSIVE
Not to mention large, and they already look sort of big already. I'm interested in the 12-35 as a single lens walk around for my Europe cruise in September but at the size they appear to be, I might just stick with the 14-140 kit and a couple primes. They'll be hard to pass on if they're sharp wide open though.I'll take the F2.8
Irrelevant, unless your only concern is DOF.How much would you pay for 70-200/5.6 for your 5D2?
No, also relevant regarding low light capability.Irrelevant, unless your only concern is DOF.How much would you pay for 70-200/5.6 for your 5D2?
