I've been using a D90 with a 18-55mm F3.5-5.6 lens for the last year. I recently inherited a Nikon 50mm F1.8 lens and was looking forward to using it, expecting better image quality than the 18-55mm.
I did a trial tonight - see photos below. Both photos were taken with the camera on a tripod, on a timer so I didn't shake the camera by pressing the button. Both were taken at F5.6 (which was wide open on the 18-55mm at 50mm focal length, but stepped down a fair bit on the 50mm F1.8).
Photo below: 18-55mm F3.5-5.6. Taken at 50mm, F5.6
Photo below: 50mm F1.8. Taken at F5.6
I was expecting the image quality to be better from the 50mm F1.8 lens, but was really disappointed. You can clearly see the image from the 50mm is much softer, especially in the centre (very obvious with the text on the boxes). I had to step down to F11 on the 50mm F1.8 before the text is as sharp as the photo taken at F5.6 with the 18-55mm.
Is there something wrong with the 50mm F1.8 lens? Does age of a lens affect the image quality? (I believe the 50mm lens is around 10 years old).
I don't know if it is the F1.8D or not (it doesn't say "D" on the lens) - see photo below, but it hasn't got the push and turn pin either of the predecessor of the "D" lens.
Would appreciate comments please. Was I right in expecting better image quality from the 50mm vs the 18-55mm ?
