I have both lenses and the TC14e. The 80-400VR is a fairly decent
unit, but does suffer from image softness above 300mm. From 350mm
to 400mm it's actually a rather poor performer.
The 80-200 is far sharper than the 80-400VR in the lower half of
the VR's zoom range. This holds true for both the AFS as well as
the AF (shaft drive AF) versions of the 80-200.
With the TC14e attached, the AFS 80-200 will be a 112-280mm zoom
and it still optically outperforms the 80-400VR in the 200-280mm
range. I think the 80-400VR is better than the 80-200 with TC14e in
the 112-200mm range.
That's a problem with teleconverters. They're really meant for use
with prime lenses, not zooms. Zooms already have too many optical
elements in them, and the TC adds several more. Oh, and don't even
think about putting the TC20e onto the AFS 80-200. The 2x is
really, really soft and, I think, only good on the AFS f2.8 prime
lenses.
Another problem is the AFS 80-200 is a much heavier lens than the
80-400VR, and one is likely to find it hard to handhold for very
long. This gets worse when the TC14e is attached as the TC moves
the lens' CG out further from the body (and the AFS 80-200 has a
fairly forward CG already).
If you know that you need range in the 300-400mm range, I would
suggest looking at the AFS 300 f4. This lens will outperform either
the 80-400VR or the AFS 80-200 with TC14e by a wide margin. The
TC14e can be added and then you have a very good performing 420mm
f5.6 lens. It's so good it's like comparing a Porsche to a Yugo.
Now, the AFS 80-200 is a pretty costly lens, and getting hard to
find. Nikon is in the process of replacing this with the AFS 70-200
f2.8G VR unit, and it appears that production of the AFS 80-200 has
ceased. There are reports of difficulties finding stock lately.
The 80-400VR is also fairly costly, but it does make for a
reasonable all-around lens for the upper end of the focal range. I
find that having an AF 28-105 f3.5-4.5D and the AF 80-400VR is a
good combination when one wants to carry a single body and a pair
of lenses. This, I think, is the primary reason to consider buying
one (and why I bought mine).
However, for a similar amount of money, one can get an AF 80-200
f2.8D, and AFS 300 f4 plus a TC14e. You trade the loss of AFS in
the 80-200 for more money in your wallet to get the AFS 300 f4
with. You could save a bit more money by getting the AF 300 f4, but
then you'd lose AF capability with the TC. In any event, the
optical performance of the AF 300 f4 is the same as for the AFS 300
f4.
So there's several lenses for you to think about as options to the
80-400VR. Just so you know, I shoot with both a Nikon D1H and a
Kodak DCS 660, both of which are heavier than the D100 and
counterbalance these longer and heavier lenses a bit better.
Stan
Just wanted to know if anyone has used (or owns) the 80-400 4.5 VR?
I am particularly interested in how it couples with the D100.
Please let me know. I feel some money burning a hole in my pocket.
Thanks!
Brian
I was wondering if anybody has compared the 80-400VR at 400mm
compared to the 80-200AFS plus the 2x tele at 400mm. I'm having a
tough time deciding what to buy.
Thanks,
James
Amateur Photographer
Professional Electronics Development Engineer
