verybiglebowski
I started to compare Samsung NX200 with Sony NEX-5n and Canon EOS 550D.
Originally I planned to do only field tests, but because of the bad weather here, I started with some studio shots.
Lack of Adobe RAW converter for NX200, forced me to use their bundled Samsung converter.
However, files that are coming from it, without sharpening are noticeably softer then those from Nex-5n and EOS 550D, developed straight in LR. (also without sharpening).
I published some results on my blog: http://verybiglobo.blogspot.com/ , and wrote about problem with conversion, but maybe someone here can have an idea why it is so.
Possible conclusions that I was able to come are:
1. Maybe, Sony and Canon add some sort of sharpening when compressing their RAW's in camera. Samsung - due to the huge RAW file size, seems to deliver pure RAW.
2. I used center focus area for AF and also MF. In MF, Sony peak assistance is really very helpful. On Canon and Samsung I have to believe my eyes and LCD's. Due to the smaller resolution of the Samsung LCD, I could misjudged sharpness, even in the highest magnification.
In AF, center square area has a different size among cameras. The problem however is, that none part of the image is sharper then Sony or Canon.
3. I tried those tests at 3 FL - 18,35 and 55mm. I published only 18mm for ISO Chart and 55mm for ISO performance. Results are even worse at 35mm for Samsung. Could it be my lens sample?
4. Any other Idea what I possibly did wrong?
I have also jpegs, the difference is obviously smaller, but I am not 100% sure about in camera jpeg engines, how similar they are. Canon has the softest JPEG, (sharpness and contrast set to +1, same as with Samsung).
Here is an example of ISO test at 800. Maybe the difference wont be that visible at small size, but at crops on my blog it is quite noticeable. I retouched those pictures here in LR in effort to equalize WB, and contrast, but the sharpening and noise reduction are still set to 0.
Sony
Samsung
Canon
http://www.flickr.com/photos/viktor_viktor/
Sony
Samsung
Canon
