In case anybody still needs to map pixels out on a e-100RS you need to set the camera control to on in the menu system. To do that open the card door with the card still in and turn on the camera, when it says card cover is open hold down the Menu button and the Monitor button at the same time for about 3 or 4 seconds and the camera control menu will pop up set it to on and close door. You should now be able to map the sensor using the program from this site http://e2500.narod.ru/ccd_defect_e.htm . remember to set the camera control back to off the same way you turned it on when your done.
