FrancoisduP
Active member
Great tip there Gerry. I am sure once I get my macro lens that I would try it out. I think I saw a similar kind of diffuser for the pop-up flash from Gary Fong. No doubt expensive...hehehehe.The problem is the same for any macro lens - deep DOF needs small aperture, which in turn slows down exposure. The answer is to use flash - the onboard is fine in most circumstances but a diffuser is needed to avoid harsh shadows. Here's my zero-cost solution.
Are you shooting a lot of macro together with "normal" photography? And if so, do you use the 35mm more as a macro lens or as an allrounder as its touted to be? The 1:2 shot looks good. I think I need to show my wife some full 1:1 macro shots so that she can decide how close or detailed she wants to get. And then compare to the 1:2 here.
Also, what made you jump from the Sigma to the Pentax?
Small lenses attract me very much. especially if they have good image quality. thats why I stay with the Pentax primes generallyAnother advantage for the Pentax is its small size. This is even more noticable for close-range shots because the hood attaches to the outer barrel; this means it doesn't go out with the front of the lens so the whole set up is more compact.
Great pic with the DFA 100mm! And thank you very much for you lengthy answer.
Francois
