Travis, is that $1.27 for the ink only? How do you break down the
cost for paper and ink? Are you using matte or glossy and do you
know if there is a price differencial? Sorry for the dumb
questions, but I am getting ready to buy a printer to print 200 to
300 real estate brochures per month for my son. Thanks much.
LSandersSr
Hi there, the $1.27 would be Leon's figure adjusted for cartrdiges
that are $10 per cart instead of $10.67 (which he used when posting
his figures). The $.77 is my figure so far on ink usage but I'm
pretty such it will end up around $1. And yes, this is just for
the ink. Note that Leon was using 2880 dpi for all his photos
while mine were mostly 1440 (about 3 pages of 2880). Both of us
were using glossy paper.
You mentioned real estate brochures. If you can determine the
approximate amount of coverage you'll need per letter-sized sheet,
then you should be able to get a ballpark figure for ink costs.
For example, let's say you determine that you'll only be covering
the page 50%. My figures are stated with an 8x10 sized coverage
area which would be 80%. So let's assume the cost of ink for an
8x10 is $1. Your cost per page would be about 63 cents if you used
the same settings and paper.
Obviously, I don't know what size your brochure will be nor the
amount of coverage you'll need. Will you be using glossy or matte
paper? Single or double sized? 720/1440/2880 dpi? All these will
affect the cost.
Take care,
Travis
