Unless something has changed, and meters are now made to much lower standards of consistency than previously, the unit is very unlikely to need calibration straight out of the box.So, straight out of the box, any need to calibrate my Sekonic 358 meter to my Nikon dSLR? Or, can I assume the Sekonic QA team calibrated the unit correctly during manufacturing?
Like many people, I thought that the light meter out of the box would be calibrated. Was I wrong. I calibrated the Sekonic 358 to my camera. After the calibration, the meter readings have been accurate (of course this will depend on how you use the meter). I had to re-calibrate the meter for the strobe that I started to use now.So, straight out of the box, any need to calibrate my Sekonic 358 meter to my Nikon dSLR? Or, can I assume the Sekonic QA team calibrated the unit correctly during manufaturing?
Of course, it could've been the camera that was off... in fact, that is more likely than the meter. Either way, you are correct in that the meter is the item adjusted to attain the match.Like many people, I thought that the light meter out of the box would be calibrated. Was I wrong. I calibrated the Sekonic 358 to my camera.So, straight out of the box, any need to calibrate my Sekonic 358 meter to my Nikon dSLR? Or, can I assume the Sekonic QA team calibrated the unit correctly during manufacture?
Well, if you are not taking readings correctly , of course, you will get errors leading to incorrect exposures. Could this have been why you thought the meter was innacurate?After the calibration, the meter readings have been accurate (of course this will depend on how you use the meter).
What? That is a RE-calibration of your "out of the box" calibration?I had to re-calibrate the meter for the strobe that I started to use now.
Well, if the Sekonic 358 is a less than reliable meter, then I stand corrected. Thank you for putting me right. However, this is all news to me, especially in light of how often the Sekonic meters are strongly recommended. In fact, my assumptions were that Sekonic had inherited the same kind of production standards as Minolta meters, of which I had used several across the years, all of which had been exceedingly accurate and reliable. Besides this, I know several people with Sekonic meters, and they have never mentioned any difficulties... (shrugs)I don't think that I'm the only one that had issues with the 358's readings. If you Google it, there are threads about it. I just read one back from 2003 (link below), where that person's 358 readings was overexposing the shot. My shots were also being overexposed per the 358 readings on ambient light.
I am still puzzled about this re-calibration you did for the strobes. Surely, making changes to the calibration in order to get the flash readings correct would have altered the previously "correct" calibration for ambient light, presumably arrived at by histogram comparison mentioned above?http://www.prophotohome.com/forum/lighting-equipment-technique/7023-sekonic-l-358-calibration.html
You can easily test the accuracy of the 358's meter reading by bracketing your shots & checking the histogram of those shots. Which shot looks properly exposed? I never had any issues on the meter readings coming from my cameras. I tested the 358's reading on strobe lighting by bracketing the shots with the camera mounted on a tripod. All is happy after adjusting the 358.
Why didn't I think about doing that test.Why not check the meter by using the sunny f/16 rule on "open sun" ?
http://en.m.wikipedia.org/wiki/Sunny_16_rule
cheers, Peter
Germany
To meet previously accepted international standards of consistency, any meter should be accurate within 1/3 stop over most of its range. Even old style analogue selenium meters achieved this, and have done so since the 1930s (Weston Master series). It happens that 1/3 f-stop is about the smallest error that would be consistently identifiable by eye AS an error... and since it is eyes we use to evaluate pictures, this degree of exposure accuracy is quite OK.I think that most of the Sekonic meters out there works great out of the box. Unfortunately, some of them don't but it doesn't mean that the ones in this group are not within factory spec. It's basically the luck of the draw with anything being mass produced.
So your meter currently has different sensitivity to flash light compared with continuous...[??] Well, that is a pretty good indication there is something wrong with it. If I were, you I'd get it sorted out.I was surprised that my adjusted 358's flash readings was off when I tested it with the strobe. I zeroed out the adjustments on the 358. Took a flash reading & bracketed the shots. The shot done per the meter reading was underexposed. This was totally opposite of the ambient light readings where they were being overexposed. I probably should send the meter back to Sekonic for an inspection. I has this meter for a few years now. As for light/flash meters out there in the market, there isn't a lot of choices out there.
Your Sunny 16 check reading should be taken in the direction of the sun, with the meter held vertically. The reading should be within 1/3 stop of f/16 for at least 4 hours either side of noon at this time of year, in the northern hemisphere.Why didn't I think about doing that test.Why not check the meter by using the sunny f/16 rule on "open sun" ?
cheers, Peter
GermanyIt was a little past noonish when I tried it out here in sunny CA. I zeroed out the adjustment on the 358. Meter settings: ISO 100, TV 100. Held the meter (dome extended) perpendicular to the ground at arms length & took four readings:
North f14
West f14
South f11
East f11
The meter didn't get f16 on a sunny day like today. I guess that this kind of proves that this particular unadjusted meter is giving out overexposed readings on ambient light which confirmed my bracketed test shots.
