New HX9V - error code E:95:00 ??
ucdcrush
Forum Enthusiast
Rancho Cordova, CA, US
I looked in the manual, and all it says for this is:
E:95:
There is trouble with the camera’s hardware. Turn the power off and on again.
Has anyone come across this error before? I had it flashing on the screen while doing some outdoor shooting... came inside, turned it on and off, it came up again.. now I have used it another 3-4 times and it is not coming up anymore. It is not a hot day and I was hardly in the sun when it happened, so I am not suspecting heat.
Anyone have an idea what it could be? This camera is only a few days old, so far I like it quite a bit but it does sometimes turn itself off then back on when processing a 3D multi angle sweep.
Well yesterday I had a problem when doing a sweep. The screen turned black and then the camera turned off and on and it did not record the sweep.
David T. Long
East Lansing, Michigan
Kodak DC220, Kodak DC265, Kodak DC 4800, Epson PhotoPC 3000Z, Olympus E-10, Olympus C-5060 Wide Zoom, Olympus C-8080 Wide Zoom, Canon 20D, Canon G9, Panasonic Lumix DMC-ZS3, Canon EOS 550D, Panasonic Lumix DMC-ZS7, Sony GH9V, Sony Bloggie 3D
Got the same problem making some first test shots with my new HX9V. The camera rebooted and displayed that error every time I took a photo until I removed and re-inserted the battery and SD card. Hope it doesn't show up again! This is one of the things you don't want to see after spending a lot of money for a Camera.
Ahh, I lost track of this post from a few days ago.
Interesting that others have had this same issue and/or the reboot while taking multi angle sweep (not 3d panorama, that always works fine for me as there is no real "processing" done after the pic is shot). I am going to keep taking test shots, sweeps etc. to see if I can figure out any pattern with it.
It is disappointing to have this issue. I have to wonder if a firmware fix would help, or if Sony has a good record with correcting errors in digicams via firmware.
I have experienced something similar on a few occasions; certainly once when using sweep panorama; on another occasion the screen went blank and completely unresponsive. Removing the battery and replacing it got it back to normal. On another couple of occasions, when turning it on, the camera would not focus on anything and was completely blurred. Again, turn it off and back on and all was OK.
I described these problems with Sony UK and they suggested sending the camera to their repair centre for analysis. I'll wait for a while before doing that.
Chris
