JimTanCanada
Hi Guys,
Early report on The Nikon CP 5700
I bought the CP5700 with some hesitation. There were many complaints on the forums. After 200 plus pictures, it is clear that the camera takes good pictures. The problem is with the camera firmware.
My previous and only digital camera was the Canon S40. So, the Nikon was a shock. The Canon was a simple, elegant and trustworthy companion. The Nikon is a power tool of unnecessary complexity that has to be mastered.
The Nikon's primary processes of focusing, metering, image capture and storage work fine.
1) Focusing works quickly and very well. Better than the small Canon. Users have had focus problems if they used the default AF Area Mode (which was intended for User Set A). Nikon should have disabled this setting for User Set 1,2, and 3.
2) In poor light, the camera locks focus immediately if there is some directed light shining on the scene. In this respect, it is superior to the Canon and its AF assist light. I have taken low light macro pictures at two-second exposures.
3) Yes, the MF is disappointing. The S40 is much worse. You cannot fit a proper MF focus system into such compact bodies.
4) The metering is constant and instantaneous. At the moment, it seems that the Nikon creates more contrast than the Canon. Will explore this further.
5) If you disable the bells and whistles, the Nikon shutter fires quickly. The problem is with saving to the CF card. If you are willing to save medium files at medium compression, the cycle time is about the same as a film camera's manual advance.
6) The cycle time for NEF and TIFF is unacceptable. In the future, better and cheaper electronics should eliminate this problem.
The Nikon's physical ergonomics is good. The camera has bulges but I can wrap my small fingers around the camera for steady shots. Every button and switch is within fingertip distance. You can change major controls without taking your eye from the EVF. No, I have not accidentally activated any buttons.
The BSS is amazing. I estimated that the Nikon's BBS and handling stability was worth 2 stops, compared to my small Canon. The swivel LCD is great.
The EVF works well for me. I wear thick glasses and I have to take them off when I review the picture on the LCD. The EVF simplifies and improves my workflow.
The Nikon has critical design and implementation flaws.
1) Time pressure must be an element in several design mistakes. The tripod mount is not centered on the lens. The lens has no native ability to mount filters. It's possible that the CP5700 successor will be a radical redesign.
2) The camera has too many options. The problem is that options create permutations exponentially. I suspect that Nikon still has a "technical" culture. Nikon has to find the will to eliminate a third of the options. Right now, Nikon is forcing the user to hack their way through the options.
3) Nikon has not sorted out the logic tree of the camera's operation. Not surprising if you consider the complexity. Hence, the problem with the AF Area Mode.
4) Some switches are redundant. The play/record switch is unnecessary. Important functions could be brought out from the menu to replace this switch.
5) The User Set function is an important milestone. But, it has been badly implemented. There should be a workspace from which User Sets can be saved and recalled.
Conclusion
1) The Canon is the user-friendly camera. It is user-friendly because of design. Nikon take note.
2) The Nikon has good SLR-like physical ergonomics, but tarnished by its software. Hasn't Nikon learned from the CP5000 public relations fiasco?
3) Yet, we must salute Nikon's aspiration to create a serious DSLR competitor. The potential is there but the CP 5700 isn't it. Not until it upgrades its firmware.
4) Nikon has to make choices and simplify its cameras. That said, the CP 5700 has improved digicam technology.
Jim Tan
Conclusion
Jim Tan
