leonard callow
Leading Member
I must be missing something- of course you don't - in the second case your image size will be 3 times the size of the first.. . . you do not get, for example, the same image if you down rez to say 100 DPI and then shrink to 8x12 as you get when you shrink to 8x12 @ 300 DPI and then down rez to 100 DPI.
say your image is 4800 x 7200 @ 300dpi- therefor 16" x 24" (@300dpi)
when you change the dpi to 100 the only change is that your image would now be 3 x the size in inches (48" x 72") -IF printed-
but the image is still 4800 x 7200 - it has not changed at all - the only thing that has changed is the instruction to the printer.
if you now say to make it 8" x 12" at 100 dpi - the image will now be reduced to 800 x 1200 pixels. whereas if you downsize to 8" x 12" @ 300 dpi your image will be reduced to 2400 x 3600 pixels which is three times the size. note that if you now were to change to 100 dpi your image does not change in any way - it remains exactly 2400 x 3600 pixels (again ONLY the instructions to the printer have changed)
this is trivial - of course the images are different.
but somehow I don't think this is what you are talking about and I must be missing what you want to convey.
Leonard
